주요 콘텐츠로 건너뛰기
Hover-1 Superstar Front Bumper LED Replacement
필요한 것
  1. Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: 1 단계, 이미지 1/3 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: 1 단계, 이미지 2/3 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: 1 단계, 이미지 3/3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Front Bumper LED Replacement: 2 단계, 이미지 1/1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Front Bumper LED Replacement, Front Bumper LED: 3 단계, 이미지 1/1
    • Grab the wire of the connector you disconnected from the case earlier and slide the entire light out away from the case.
결론
Keegan
회원 가입일: 10/04/18
632 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 276
