주요 콘텐츠로 건너뛰기
Hover-1 Superstar Speaker Replacement
필요한 것
  1. Hover-1 Superstar Speaker Replacement, Bottom Case: 1 단계, 이미지 1/3 Hover-1 Superstar Speaker Replacement, Bottom Case: 1 단계, 이미지 2/3 Hover-1 Superstar Speaker Replacement, Bottom Case: 1 단계, 이미지 3/3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Speaker Replacement: 2 단계, 이미지 1/1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Unplug the white connector that connects the speaker itself with the circuit board attached to the bottom of the device case.
  4. Hover-1 Superstar Speaker Replacement: 4 단계, 이미지 1/1
    • Unscrew all three 9mm screws with a Phillips #0 screwdriver securing the speaker to the device case.
  5. Hover-1 Superstar Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the speaker from its port.
결론
Keegan
회원 가입일: 10/04/18
632 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 265
