주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
부품
지정된 부품이 없습니다.
  1. Flip the hoverboard so the bottom is facing up. The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    키트 쇼핑하기
    Enough RAM
    For All The Tabs
    키트 쇼핑하기
  3. Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  4. Grip the bottom left panel and lift up to remove. Grip the bottom left panel and lift up to remove. Grip the bottom left panel and lift up to remove.
    • Grip the bottom left panel and lift up to remove.
결론
Dana Ebe
회원 가입일: 2018년 10월 08일
205 평판
안내서 2개 작성하였습니다
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 회원
CPSU-WHITE-F18S15G4
4 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 30
