주요 콘텐츠로 건너뛰기
Hover-1 Titan Charge Port Replacement
필요한 것
  1. Hover-1 Titan Charge Port Replacement, Bottom Left Panel: 1 단계, 이미지 1/2 Hover-1 Titan Charge Port Replacement, Bottom Left Panel: 1 단계, 이미지 2/2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Charge Port Replacement: 2 단계, 이미지 1/2 Hover-1 Titan Charge Port Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Charge Port Replacement: 3 단계, 이미지 1/3 Hover-1 Titan Charge Port Replacement: 3 단계, 이미지 2/3 Hover-1 Titan Charge Port Replacement: 3 단계, 이미지 3/3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Charge Port Replacement, Charge Port: 4 단계, 이미지 1/3 Hover-1 Titan Charge Port Replacement, Charge Port: 4 단계, 이미지 2/3 Hover-1 Titan Charge Port Replacement, Charge Port: 4 단계, 이미지 3/3
    • Unplug the red and black charge port wire from the motherboard by squeezing the connector located at the top right of the motherboard and pulling the connector away from the board.
  5. Hover-1 Titan Charge Port Replacement: 5 단계, 이미지 1/3 Hover-1 Titan Charge Port Replacement: 5 단계, 이미지 2/3 Hover-1 Titan Charge Port Replacement: 5 단계, 이미지 3/3
    • Use an adjustable wrench to loosen the 14 mm nut and lift it off the charge port.
  6. Hover-1 Titan Charge Port Replacement: 6 단계, 이미지 1/2 Hover-1 Titan Charge Port Replacement: 6 단계, 이미지 2/2
    • Remove the old charge port by pulling the wires all the way through the panel.
    • Replace the old charge port with the new charge port.
결론
Jessica Ouyang
회원 가입일: 10/08/18
619 평판
안내서 4개 작성하였습니다
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 회원
CPSU-WHITE-F18S15G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 693
