이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If the charge port on your Hover-1 Titan is no longer charging your hoverboard, this guide will explain how to replace it.
필요한 것
Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
Unplug the red and black charge port wire from the motherboard by squeezing the connector located at the top right of the motherboard and pulling the connector away from the board.
