주요 콘텐츠로 건너뛰기
Hover-1 Titan Left Gyroscope Replacement
필요한 것
  1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: 1 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: 1 단계, 이미지 2개 중 2개
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Left Gyroscope Replacement: 2 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Left Gyroscope Replacement: 3 단계, 이미지 3개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 3 단계, 이미지 3개 중 2개 Hover-1 Titan Left Gyroscope Replacement: 3 단계, 이미지 3개 중 3개
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: 4 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: 4 단계, 이미지 2개 중 2개
    • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Left Gyroscope Replacement: 5 단계, 이미지 3개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 5 단계, 이미지 3개 중 2개 Hover-1 Titan Left Gyroscope Replacement: 5 단계, 이미지 3개 중 3개
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Left Gyroscope Replacement: 6 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 6 단계, 이미지 2개 중 2개
    • Unplug the bottom right connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Left Gyroscope Replacement: 7 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 7 단계, 이미지 2개 중 2개
    • Unplug the light connector by squeezing it and pulling away from the board.
  8. Hover-1 Titan Left Gyroscope Replacement: 8 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 8 단계, 이미지 2개 중 2개
    • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Left Gyroscope Replacement: 9 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 9 단계, 이미지 2개 중 2개
    • Unplug the small white connector by squeezing it and pulling away from the board.
  10. Hover-1 Titan Left Gyroscope Replacement: 10 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 10 단계, 이미지 2개 중 2개
    • Unplug the plug in the red connector.
    • The red plug is glued to the board, so this step will require extra force.
  11. Hover-1 Titan Left Gyroscope Replacement: 11 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 11 단계, 이미지 2개 중 2개
    • Unplug the charging cable connector by squeezing it and pulling it away from the board.
  12. Hover-1 Titan Left Gyroscope Replacement: 12 단계, 이미지 1개 중 1개
    • Cut the cable tie.
    • Unplug the remaining wires.
    • The connectors for the remaining wires are in the rubber covers.
결론
작성자
4다른 기여자 명과 함께
Jessica Ouyang
회원 가입일: 10/08/18
634 평판
안내서 4개를 작성함
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 회원
CPSU-WHITE-F18S15G4
4 회원들
안내서 10개를 작성함
2가이드 댓글
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - 답글
Where do you buy the board?
eden11 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 24
전체 시간: 1,403
