주요 콘텐츠로 건너뛰기
Hover-1 Titan Wheel and Motor Replacement
필요한 것
  1. Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: 1 단계, 이미지 2개 중 1개 Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: 1 단계, 이미지 2개 중 2개
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Wheel and Motor Replacement: 2 단계, 이미지 2개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Wheel and Motor Replacement: 3 단계, 이미지 3개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 3 단계, 이미지 3개 중 2개 Hover-1 Titan Wheel and Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: 4 단계, 이미지 2개 중 1개 Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: 4 단계, 이미지 2개 중 2개
    • Unplug the battery by pulling apart the yellow connectors.
  5. Hover-1 Titan Wheel and Motor Replacement: 5 단계, 이미지 2개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
  6. Hover-1 Titan Wheel and Motor Replacement: 6 단계, 이미지 3개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 6 단계, 이미지 3개 중 2개 Hover-1 Titan Wheel and Motor Replacement: 6 단계, 이미지 3개 중 3개
    • Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
  7. Hover-1 Titan Wheel and Motor Replacement: 7 단계, 이미지 2개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 7 단계, 이미지 2개 중 2개
    • Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
  8. Hover-1 Titan Wheel and Motor Replacement: 8 단계, 이미지 3개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 8 단계, 이미지 3개 중 2개 Hover-1 Titan Wheel and Motor Replacement: 8 단계, 이미지 3개 중 3개
    • Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
  9. Hover-1 Titan Wheel and Motor Replacement: 9 단계, 이미지 2개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 9 단계, 이미지 2개 중 2개
    • Unplug the green wires by gripping the wire close to the connectors and pulling apart.
  10. Hover-1 Titan Wheel and Motor Replacement: 10 단계, 이미지 3개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 10 단계, 이미지 3개 중 2개 Hover-1 Titan Wheel and Motor Replacement: 10 단계, 이미지 3개 중 3개
    • Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
  11. Hover-1 Titan Wheel and Motor Replacement: 11 단계, 이미지 2개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 11 단계, 이미지 2개 중 2개
    • Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
  12. Hover-1 Titan Wheel and Motor Replacement: 12 단계, 이미지 3개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 12 단계, 이미지 3개 중 2개 Hover-1 Titan Wheel and Motor Replacement: 12 단계, 이미지 3개 중 3개
    • Unplug the rainbow connector by squeezing the clips and pulling apart.
  13. Hover-1 Titan Wheel and Motor Replacement: 13 단계, 이미지 2개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 13 단계, 이미지 2개 중 2개
    • Use scissors to cut the zip tie around the group of wires.
  14. Hover-1 Titan Wheel and Motor Replacement: 14 단계, 이미지 3개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 14 단계, 이미지 3개 중 2개 Hover-1 Titan Wheel and Motor Replacement: 14 단계, 이미지 3개 중 3개
    • Unplug the white wire connector by squeezing the clips and pulling apart.
  15. Hover-1 Titan Wheel and Motor Replacement: 15 단계, 이미지 2개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 15 단계, 이미지 2개 중 2개
    • Use an impact driver with a hex 6 bit to loosen the four 20 mm hex 6 bolts.
    • Wear safety glasses while using the impact driver.
  16. Hover-1 Titan Wheel and Motor Replacement: 16 단계, 이미지 3개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 16 단계, 이미지 3개 중 2개 Hover-1 Titan Wheel and Motor Replacement: 16 단계, 이미지 3개 중 3개
    • Pull out the loosened screws with your hands and remove the metal plate.
  17. Hover-1 Titan Wheel and Motor Replacement: 17 단계, 이미지 2개 중 1개 Hover-1 Titan Wheel and Motor Replacement: 17 단계, 이미지 2개 중 2개
    • Lift the wheel and motor shaft up and out of the board.
    • The motor shaft is located within the wheel.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Emma Huun
회원 가입일: 10/08/18
321 평판
안내서 1개를 작성함
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 회원
CPSU-WHITE-F18S15G4
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 36
전체 시간: 2,423
