주요 콘텐츠로 건너뛰기
Hover-1 Ultra Charging Port Replacement
필요한 것
  1. Hover-1 Ultra Charging Port Replacement, Charging Port: 1 단계, 이미지 1/3 Hover-1 Ultra Charging Port Replacement, Charging Port: 1 단계, 이미지 2/3 Hover-1 Ultra Charging Port Replacement, Charging Port: 1 단계, 이미지 3/3
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Hover-1 Ultra Charging Port Replacement: 2 단계, 이미지 1/2 Hover-1 Ultra Charging Port Replacement: 2 단계, 이미지 2/2
    • Using your hands or a crescent wrench, begin removing the charging port.
    • Turn the charging port counter-clockwise to release it from the shell.
  3. Hover-1 Ultra Charging Port Replacement: 3 단계, 이미지 1/3 Hover-1 Ultra Charging Port Replacement: 3 단계, 이미지 2/3 Hover-1 Ultra Charging Port Replacement: 3 단계, 이미지 3/3
    • Unclip the insulated red and black wires attached to the port from the motherboard
  4. Hover-1 Ultra Charging Port Replacement: 4 단계, 이미지 1/3 Hover-1 Ultra Charging Port Replacement: 4 단계, 이미지 2/3 Hover-1 Ultra Charging Port Replacement: 4 단계, 이미지 3/3
    • Remove the charging port through the assembly.
    • Place new charging port through the assembly.
    • Clip red and black insulated wires into the motherboard.
결론
To reassemble your device, follow the instructions for step 1 in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Camron Clifton
회원 가입일: 10/22/18
409 평판
안내서 3개 작성하였습니다
UC Davis, Team S7-G5, Lore Fall 2018 UC Davis, Team S7-G5, Lore Fall 2018 회원
UCD-LORE-F18S7G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 12
전체 시간: 737
