소개
If the bike is not performing at its maximum capability, its battery may be corroded, and you should replace it as soon as possible. Before beginning this guide, you will need power tools or a chemical remover to deal with Teflon tape on the screws.
필요한 것
Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 7개
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David did you happen to find one? Please let me know I've been looking for one
has anyone been able to find the battery replacement ? any links ?
Fabulous P - 답글
