소개
To replace the front wheel you have to remove the front brakes first, so follow the instructions below. To remove the front wheels, you also have to take off the two front hub caps. The screws on the hub caps have Teflon, so you will need to either apply B'laster or a similar chemical remover onto the screws or use a power tool.
필요한 것
Remove the two, 23 mm Hex #5 screws holding the brake to the bike.
Slide the brake mechanism off and turn it upside down to reveal the screw holding the brake wire.
Remove the two, 16 mm Hex #4 screws on both of the hub caps in the front wheel.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
How do I get in touch with customer service for parts?
tried filling out the form on computer and phone as well tablet and it says error.
fox_Jayson@yahoo.com
please reach out
