주요 콘텐츠로 건너뛰기
Hover-1 XLS Ignition Replacement
필요한 것
  1. Hover-1 XLS Ignition Replacement, Ignition: 1 단계, 이미지 1개 중 1개
    • Remove the six 16mm #3 Hex head screws located on the front panel.
    • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
  2. Hover-1 XLS Ignition Replacement: 2 단계, 이미지 3개 중 1개 Hover-1 XLS Ignition Replacement: 2 단계, 이미지 3개 중 2개 Hover-1 XLS Ignition Replacement: 2 단계, 이미지 3개 중 3개
    • Grab the front panel and gently lift it up to the side.
    • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
  3. Hover-1 XLS Ignition Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two, 19 mm Phillips #2 screws holding the ignition.
    • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
결론
작성자
3다른 기여자 명과 함께
Jonathan Hidalgo
회원 가입일: 01/24/19
632 평판
안내서 5개를 작성함
Cal Poly, Team S1-G2, White Winter 2019 Cal Poly, Team S1-G2, White Winter 2019 회원
CPSU-WHITE-W19S1G2
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 1,327
