주요 콘텐츠로 건너뛰기
Hover-1 XLS LCD Screen Replacement
필요한 것
  1. Hover-1 XLS LCD Screen Replacement, Ignition: 1 단계, 이미지 1/1
    • Remove the six 16mm #3 Hex head screws located on the front panel.
    • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
  2. Hover-1 XLS LCD Screen Replacement: 2 단계, 이미지 1/3 Hover-1 XLS LCD Screen Replacement: 2 단계, 이미지 2/3 Hover-1 XLS LCD Screen Replacement: 2 단계, 이미지 3/3
    • Grab the front panel and gently lift it up to the side.
    • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
  3. Hover-1 XLS LCD Screen Replacement: 3 단계, 이미지 1/1
    • Remove the two, 19 mm Phillips #2 screws holding the ignition.
    • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
  4. Hover-1 XLS LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1/3 Hover-1 XLS LCD Screen Replacement, LCD Screen: 4 단계, 이미지 2/3 Hover-1 XLS LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3/3
    • Remove the four 10mm Phillips #2 screws holding the casing of the LCD.
    • Remove the casing on the LCD.
  5. Hover-1 XLS LCD Screen Replacement: 5 단계, 이미지 1/3 Hover-1 XLS LCD Screen Replacement: 5 단계, 이미지 2/3 Hover-1 XLS LCD Screen Replacement: 5 단계, 이미지 3/3
    • Remove the four 10mm Phillips #2 screws holding the LCD onto the bike.
    • Gently lift off the LCD screen.
    • Follow iFixit's soldering guide to remove the LCD screen.
결론
Jonathan Hidalgo
회원 가입일: 01/24/19
575 평판
안내서 5개 작성하였습니다
Cal Poly, Team S1-G2, White Winter 2019 Cal Poly, Team S1-G2, White Winter 2019 회원
CPSU-WHITE-W19S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 31
전체 시간: 1,235
