주요 콘텐츠로 건너뛰기
소개
OWC’s Envoy Pro enclosures allow you to repurpose a factory-installed Mac SSD as a portable external drive. Follow this guide to learn how to install your SSD into the enclosure.
If you still need to complete your SSD upgrade, find your Mac starting from this page and look for the SSD Replacement guide.
Note: OWC Envoy Pro enclosures are designed for use with factory-installed Mac Solid State Drives, and will not work with other PCIe replacement drives and adapters, including OWC’s own Aura Pro drive.
  1. To open the enclosure, pull the top half down toward the wedged end and lift it away from the bottom half. To open the enclosure, pull the top half down toward the wedged end and lift it away from the bottom half. To open the enclosure, pull the top half down toward the wedged end and lift it away from the bottom half.
    • To open the enclosure, pull the top half down toward the wedged end and lift it away from the bottom half.
  2. Carefully insert your Mac OEM SSD as shown at left, with the golden contact pads below the connector pins facing upward. The SSD might take a significant amount of force to insert. Make sure you have the orientation correct before you apply any pressure. When the SSD is fully inserted, you should barely be able to see the golden contact points at the top of the drive, and the notch at the bottom of the drive should be aligned with the hole for the screw in the enclosure.
    • Carefully insert your Mac OEM SSD as shown at left, with the golden contact pads below the connector pins facing upward.
    • The SSD might take a significant amount of force to insert. Make sure you have the orientation correct before you apply any pressure.
    • When the SSD is fully inserted, you should barely be able to see the golden contact points at the top of the drive, and the notch at the bottom of the drive should be aligned with the hole for the screw in the enclosure.
  3. Use a T5 Torx driver to install the 6.5 mm screw securing the bottom of the SSD.
    • Use a T5 Torx driver to install the 6.5 mm screw securing the bottom of the SSD.
  4. Reinstall the top half of the enclosure and slide it closed. Reinstall the top half of the enclosure and slide it closed. Reinstall the top half of the enclosure and slide it closed.
    • Reinstall the top half of the enclosure and slide it closed.
  5. Use a T5 Torx driver to install the two 7.6 mm screws on the bottom of the enclosure.
    • Use a T5 Torx driver to install the two 7.6 mm screws on the bottom of the enclosure.
  6. Remove the backing from the adhesive on the extra rubber foot provided in the plastic bag with the screws. With the backing removed, place the sticky side of the rubber foot down over the screws you just inserted, and apply pressure to it for 30 seconds. With the backing removed, place the sticky side of the rubber foot down over the screws you just inserted, and apply pressure to it for 30 seconds.
    • Remove the backing from the adhesive on the extra rubber foot provided in the plastic bag with the screws.
    • With the backing removed, place the sticky side of the rubber foot down over the screws you just inserted, and apply pressure to it for 30 seconds.
  7. The drive is now ready to be connected to your computer with the included USB cable.
    • The drive is now ready to be connected to your computer with the included USB cable.
결론
Once your drive is installed, you can transfer data from it, or use Disk Utility to format it and use it as a Time Machine backup.
다른 13명이 해당 안내서를 완성하였습니다.
Taylor Dixon
회원 가입일: 2018년 06월 26일
51,209 평판
안내서 94개 작성하였습니다
Teardown Team Teardown Team 회원
Community
2 회원들
안내서 2,014개 작성하였습니다
댓글 3개
Does anyone know why the OWC Envoy Pro enclosure DOES NOT work with the OWC’s Aura Pro drive? I have noticed the warning (included above as well) that the enclosure only works with “factory-installed Mac Solid State Drives”. One would think that if the OWC Aura Pro drive can serve as a replacement for a Mac SSD that it should work in the Envoy Pro enclosure as well. The reason that I ask is that it would be much easier to format and transfer data to the Aura Pro drive via the enclosure rather than having to do this all after installation in the Mac computer.
markbrandon - 답글
I have OWC 480Gb SSD for MacBookAir mid 2012. I called OWC to ask the same question. I was told that it actually was a Heat matter, that it would work but at my own risk. I feel I was lucky to get that response and that they probably do not give it any more. I tried it with success, keeping the Enclosure lid open. I would not use it extensively though. For extra safety you can always use a small fan to cool it up. I think you can respect their recommandations by booting from the external enclosure with the original Mac SSD in it and then Clone it to the internal freshly formatted OWC SSD. I now have another OWC 480Gb SSD for MacBookAir 2015. Am I going to have the guts to also give it a try ? Just to play safe I will try not to. So I would suggest that a Heat Monitoring Program be installed and that both Original Apple and OWC SSD Temperature be monitored and compared.
Midu - 답글
12312312312312312
vasiliy -
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 44
30일 전: 191
전체 시간: 10,829
