주요 콘텐츠로 건너뛰기
How To Clean Car Floor Mats
필요한 것
  1. How To Clean Car Floor Mats, How To Clean Car Floor Mats: 1 단계, 이미지 1개 중 1개
    • Soak the floor mat generously with water.
    • I used this power washer for the procedure, but it's totally unnecessary. You can just use a regular water hose.
    • Bonus: if you're doing it right, a rainbow will manifest itself to congratulate you.
  2. How To Clean Car Floor Mats: 2 단계, 이미지 1개 중 1개
    • Spread your favorite granule-based, eco-friendly laundry detergent onto the entire area of the floor mat.
    • Why eco-friendly? This soapy gray water will go down the curb and into your favorite creek. So be nice to it!
    • You don't have to use a whole bunch, as the stuff is quite soapy. Just have enough sprinkled so that most of the mat is covered.
  3. How To Clean Car Floor Mats: 3 단계, 이미지 1개 중 1개
    • Scrub like crazy with a push broom. As you can see in the photo, I'm preventing the mat from moving by standing on an edge.
    • Brush in a couple of different directions so you agitate all the contaminants from various angles.
    • No push broom (or other stiff brush) handy? No problem! Take your shoes and socks off, and scrub with your feet. Just be careful to not slip off the mat. You do not want to rub your feet up against concrete, or whatever surface the mat is on.
    • As a bonus, you will have the cleanest feet in the tri-state area after this procedure.
  4. How To Clean Car Floor Mats: 4 단계, 이미지 1개 중 1개
    • Thoroughly wash off the soap:
    • Start on one edge of the floor mat and push the soap all the way across the mat.
    • Repeat the rinsing until juices run clear, so to speak.
  5. How To Clean Car Floor Mats: 5 단계, 이미지 2개 중 1개 How To Clean Car Floor Mats: 5 단계, 이미지 2개 중 2개
    • Repeat for all of the other floor mats in the car.
    • Bonus tip: If you want extra-clean sneakers, now's the time to scrub them as well! just detach the broom from the handle, or use a wet sock to agitate the dirt on each sneaker.
결론
Put the floor mats back into the car (or truck) once they've finished drying.
다른 32명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Miroslav Djuric
160,236 평판
안내서 144개를 작성함
7가이드 댓글
May I recommend that one use an environmentally friendly detergent. As one hoses off the mat, the soapy water will flow to the gutter, and ultimately to a river or ocean.
Josh - 답글
You know, I never considered that. Thanks for the heads-up! I added a note on the guide so that folks are informed.
Miroslav Djuric -
Absolutely love the funniness! Very easy to understand simple steps.
hellokittylynn3 - 답글
Err…. Why would you not just put the mats in a washing machine???
Alex Lee - 답글
Love your wit! Gotta love a clean freak!
Might I suggest deLimonine (100% of course) from orange peels. (I get mine shipped from canada & use it for everything…. even adhesive removal. Lasts forever.
I tried to give you 30 points but I havn’t completed the job & it made me take it back!
Also Alex Lee! If you do that to a washing machine it won’t be long till you are writing a repair manual for it!
Nancy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 57
지난 30일: 216
전체 시간: 56,391
