이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Read and follow the iMac Intel 20" EMC 2105 and 2118 Display Replacement guide, and remove your screen completely.
Flip the screen over, placing it on a towel to keep it safe. Locate the manufacturer's sticker on the back of the screen, which should contain the screen's Model Number
The screen used in this particular iMac 20" A#### EMC#### is an LG-brand model-LM201W01, though yours may be different.
Search either AliExpress.com or Ebay.com using the search phrase “Your-Screen-Model-Number Control Board”.
If your iMac is a 20", they should be around $30-$40. If 24", $60-$80.
Order the video driver board for your screen. It will probably ship from Asia, and take 2-3 weeks to get to you.
It probably will not come with a power supply. This is normal. Most video control boards require 12v 5A power supplies. You may have one in your spare electronics bin, so check there before buying one: Old routers, PC laptops, etc may have compatible power supplies.
Follow X guide for complete iMac disassembly.
Placeholder for info about build
다른 2명이 해당 안내서를 완성하였습니다.
댓글 5개
Hi, will this page be completed? I would love to mod my 2011 iMac
I have news. I normally use my old iMac as an external monitor with my macbook pro, connecting it via the firewire port and adapter.
I had to use the SwitchResX app to get a decent screen size and experienced only very sluggish performance.
Today i discovered that you can get far better results with native macOs stuff. Doing:
System Settings -> Displays -> Show resolutions as list -> Show all resolutions
works like a charm, with a lag that is very acceptable. I have no idea when this feature showed up.
It has been a long wait, but thank you apple.
Can you do this with a Mac (27-inch, Late 2012)?
