주요 콘텐츠로 건너뛰기
How To Dye Faded Canvas Shoes
필요한 것
  1. How To Dye Faded Canvas Shoes, How To Dye Faded Canvas Shoes: 1 단계, 이미지 1/2 How To Dye Faded Canvas Shoes, How To Dye Faded Canvas Shoes: 1 단계, 이미지 2/2
    • Mix a few drops of detergent with water in the bucket. You should add about 3 drops of detergent for every 10 oz of water.
    • Do not add too much detergent. If the solution becomes too bubbly or overly soapy, there is too much detergent in the solution.
  2. How To Dye Faded Canvas Shoes: 2 단계, 이미지 1/2 How To Dye Faded Canvas Shoes: 2 단계, 이미지 2/2
    • Dip entire scrubbing device (toothbrush or sponge) into solution.
    • Lightly scrub the faded material with the scrubbing device.
    • Be gentle. Do not scrub too hard. This will damage the suede shoe.
  3. How To Dye Faded Canvas Shoes: 3 단계, 이미지 1/2 How To Dye Faded Canvas Shoes: 3 단계, 이미지 2/2
    • Lightly tap the faded canvas carefully with a towel or paper towel to dry it
    • Again, be gentle with the material so you do not damage it.
    • Leave the shoe out to air dry. It should take about 1-2 hours to completely dry.
  4. How To Dye Faded Canvas Shoes: 4 단계, 이미지 1/1
    • Dip the utensil into the dye. Completely cover the utensil in dye.
  5. How To Dye Faded Canvas Shoes: 5 단계, 이미지 1/3 How To Dye Faded Canvas Shoes: 5 단계, 이미지 2/3 How To Dye Faded Canvas Shoes: 5 단계, 이미지 3/3
    • Apply the dye to the faded area of the shoe.
    • Apply lightly over the entire surface of faded area in a circular motion.
    • Be careful not to get any dye on your skin.
  6. How To Dye Faded Canvas Shoes: 6 단계, 이미지 1/2 How To Dye Faded Canvas Shoes: 6 단계, 이미지 2/2
    • Allow the dye to dry.
    • Refer to the canvas dye directions for drying time. It should take about 1-2 hours to be completely dry.
결론
When the color of your shoes has been completely restored, you are finished. For other shoe related issues, there are other guides on iFixit that can help.
다른 17명이 해당 안내서를 완성하였습니다.
Ryan Thomson
회원 가입일: 04/09/15
737 평판
안내서 1개 작성함
Cal Poly, Team 28-6, Green Spring 2015 Cal Poly, Team 28-6, Green Spring 2015 회원
CPSU-GREEN-S15S28G6
4 회원들
안내서 10개 작성하였습니다
댓글 5개
The color had faded due to display for a period of time, how to restore its color as it is a stripe one
joyjpastoral - 답글
how long this color work on product i means what is their age i found some good detail for dye please check and let me know is correct or not ?
Munna Dyes Chem
Munna Dyes - 답글
The colour has faded due to washing them how to restore its colour as they are stripe ones
pollandnik - 답글
so i have checkered vans and i cleaned it like that but with just water anD THE ENDS FADED how do i restore the checkers?
jenna - 답글
My shoes are leafy green what am i gonna do about it.?
Rocky Bhai - 답글
댓글 쓰기
조회 통계:
24 시간 전: 29
7일 전: 215
30일 전: 973
전체 시간: 186,107
