주요 콘텐츠로 건너뛰기
How To Fix A Broken Makeup Brush
필요한 것
  1. How To Fix A Broken Makeup Brush, How To Fix A Broken Makeup Brush: 1 단계, 이미지 1/2 How To Fix A Broken Makeup Brush, How To Fix A Broken Makeup Brush: 1 단계, 이미지 2/2
    • Remove excess glue on the handle and the base of the brush using a nail file.
  2. How To Fix A Broken Makeup Brush: 2 단계, 이미지 1/1
    • Use the hot glue gun to apply glue to the inside base of the brush where the handle is attached.
    • Be cautious of the high temperature of the glue and gun when handling.
  3. How To Fix A Broken Makeup Brush: 3 단계, 이미지 1/1
    • Slowly place the brush head onto the handle and apply pressure for 15 seconds.
  4. How To Fix A Broken Makeup Brush: 4 단계, 이미지 1/1
    • Remove excess glue from the brush using a paper towel.
  5. How To Fix A Broken Makeup Brush: 5 단계, 이미지 1/1
    • Let the glue dry for 2-3 minutes to be sure it is securely attached.
결승점
Shanae Swack
회원 가입일: 02/23/16
403 평판
안내서 1개 작성함
Texas Tech, Team 26-4, Rauch Spring 2016 Texas Tech, Team 26-4, Rauch Spring 2016 회원
TTU-RAUCH-S16S26G4
3 회원들
안내서 1개 작성하였습니다
댓글 한 개
Amazing!!! Thanks a lot.
Amal - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 31
전체 시간: 6,008
