주요 콘텐츠로 건너뛰기
How To Fix A Hole In Khaki Pants
필요한 것
  1. How To Fix A Hole In Khaki Pants, How To Fix A Hole In Khaki Pants: 1 단계, 이미지 1/1
    • Examine the damaged area.
    • Make sure to clean all the debris from the tear.
  2. How To Fix A Hole In Khaki Pants: 2 단계, 이미지 1/1
    • Flip your pants inside out.
  3. How To Fix A Hole In Khaki Pants: 3 단계, 이미지 1/1
    • Pinch hole together.
    • Make sure there is no gaps showing.
  4. How To Fix A Hole In Khaki Pants: 4 단계, 이미지 1/1
    • Pin needle and thread through pants.
    • Use more thread than needed so you will have enough.
    • Make sure your hand is not directly behind the needle where you are poking. This will prevent you from pricking yourself.
  5. How To Fix A Hole In Khaki Pants: 5 단계, 이미지 1/2 How To Fix A Hole In Khaki Pants: 5 단계, 이미지 2/2
    • Pull needle and thread through pants until there is only 2 inches of thread left.
    • Tie a knot at the end of the remaining 2 inches.
    • It can be any measurement, but 2 inches makes it easier to tie a knot without wasting too much thread.
  6. How To Fix A Hole In Khaki Pants: 6 단계, 이미지 1/2 How To Fix A Hole In Khaki Pants: 6 단계, 이미지 2/2
    • Take the needle and pin it through right next to the previous spot.
    • Pull all the way through until thread is tight.
    • Repeat this process until you reach the end of the hole.
  7. How To Fix A Hole In Khaki Pants: 7 단계, 이미지 1/1
    • Wrap the thread three times around the needle.
    • Pull the needle until the thread is tight.
    • This will tie a knot at the end.
  8. How To Fix A Hole In Khaki Pants: 8 단계, 이미지 1/1
    • Take the scissors and cut the excess string remaining.
  9. How To Fix A Hole In Khaki Pants: 9 단계, 이미지 1/1
    • Now put your khaki pants on because they are now wearable again and practically new!
결론
Now your old ripped pants look practically new and you can begin wearing them again.
다른 6명이 해당 안내서를 완성하였습니다.
Calvin Roth
회원 가입일: 09/27/15
291 평판
안내서 1개 작성함
Cal Poly, Team 17-1, Green Fall 2015 Cal Poly, Team 17-1, Green Fall 2015 회원
CPSU-GREEN-F15S17G1
4 회원들
안내서 5개 작성하였습니다
댓글 5개
it's 100% not ok...... i con do it so 99% ok
Shafikahmed - 답글
Iam shafik i can't do it's and 100% maching
Shafikahmed - 답글
What about if you’re in school and your pants rip?
EMMA MILLER - 답글
is it smooth when you fix it? i use these for school and dont want it to show
JORDI ZAMUDIO - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 27
30일 전: 135
전체 시간: 51,019
