주요 콘텐츠로 건너뛰기
How To Fix A Paper Towel Dispenser
필요한 것
  1. How To Fix A Paper Towel Dispenser, How To Fix A Paper Towel Dispenser: 1 단계, 이미지 2개 중 1개 How To Fix A Paper Towel Dispenser, How To Fix A Paper Towel Dispenser: 1 단계, 이미지 2개 중 2개
    • Open the paper-towel dispenser's cover using your Philips head screwdriver and turn it counter-clockwise.
    • Some paper-towel dispensers require a key to unlock them. The lock is generally located on the top of the paper-towel dispenser.
  2. How To Fix A Paper Towel Dispenser: 2 단계, 이미지 1개 중 1개
    • Look for jams. Check every space inside the paper-towel dispenser for wads of paper towels. Remove any stray bits of paper towel that you find.
  3. How To Fix A Paper Towel Dispenser: 3 단계, 이미지 1개 중 1개
    • Tear off the paper towels just above the rollers.
    • Remove the roll of paper towels. Pull the lever of the paper-towel dispenser a few times to dislodge any remaining paper towels.
  4. How To Fix A Paper Towel Dispenser: 4 단계, 이미지 3개 중 1개 How To Fix A Paper Towel Dispenser: 4 단계, 이미지 3개 중 2개 How To Fix A Paper Towel Dispenser: 4 단계, 이미지 3개 중 3개
    • Replace the roll of paper towels. Make sure the roll is coming over the top towards you. Sometimes the paper towels will still come out of the dispenser if the roll is backward, but will tear off inside the dispenser and cause jams.
    • Push holsters outwards when attempting to put a new roll in.
  5. How To Fix A Paper Towel Dispenser: 5 단계, 이미지 3개 중 1개 How To Fix A Paper Towel Dispenser: 5 단계, 이미지 3개 중 2개 How To Fix A Paper Towel Dispenser: 5 단계, 이미지 3개 중 3개
    • Feed the paper towels through the rollers. Pull the paper-towel dispenser's lever three or four times to make sure the paper is completely fed through.
    • Don't get your fingers caught!
  6. How To Fix A Paper Towel Dispenser: 6 단계, 이미지 1개 중 1개
    • Close the paper-towel dispenser's cover. Turn tool clockwise to lock. If there is a key, lock the paper-towel dispenser.
결론
To repair your device, follow these instructions in order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jeevan Vase
회원 가입일: 02/24/15
138 평판
안내서 1개를 작성함
Cal Poly, Team 24-5, Green Winter 2015 Cal Poly, Team 24-5, Green Winter 2015 회원
CPSU-GREEN-W15S24G5
3 회원들
안내서 4개를 작성함
5가이드 댓글
What to do if the screw on the top rotates freely and does not open the dispenser? How to open the dispenser then?
sheinsalu - 답글
same problem!!! how do you open it if just keep turning?
Nena Keller - 답글
Use a flat head and go deeper
Deborah Sharkey - 답글
What if your dispenser is old ? Can the springs be replaced?
Julie Newton - 답글
The paper towel dispenser only dispenses a 4” sheet of paper no matter what setting size it is on. What can I do to increase the length of the towel?
greg theus - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 35
지난 30일: 127
전체 시간: 60,199
