소개
Have a broken paper towel dispenser? Completely stumped as to how to fix it? Use this guide to repair your dispenser quickly and easily.
필요한 것
Open the paper-towel dispenser's cover using your Philips head screwdriver and turn it counter-clockwise.
Close the paper-towel dispenser's cover. Turn tool clockwise to lock. If there is a key, lock the paper-towel dispenser.
this is how to load in paper…how do you fix it if the paper doesn’t always turn on rollers?
To repair your device, follow these instructions in order.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 4개
same problem!!! how do you open it if just keep turning?
Use a flat head and go deeper
What if your dispenser is old ? Can the springs be replaced?
