주요 콘텐츠로 건너뛰기
How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan
필요한 것
  1. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan, How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: 1 단계, 이미지 1/1
    • remove the three Phillips screws under the fan closest to the video ports of the card
  2. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: 2 단계, 이미지 1/1
    • Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
  3. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: 3 단계, 이미지 1/1
    • Reassemble and re-install the card into your computer. It should stop the vibration.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Matthew Johnson
회원 가입일: 04/07/12
392 평판
안내서 1개 작성함
댓글 한 개
Can you post a picture showing how its fit in the fins?
Gustavo Horta - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 8,308
