주요 콘텐츠로 건너뛰기
How To Fix Torn Winter Earmuffs
필요한 것
  1. How To Fix Torn Winter Earmuffs, How To Fix Torn Winter Earmuffs: 1 단계, 이미지 1개 중 1개
    • Cut approximately 30 cm of thread with scissors.
    • The thread length will vary depending on the size of the area that needs to be sewn.
  2. How To Fix Torn Winter Earmuffs: 2 단계, 이미지 1개 중 1개
    • Insert the sewing thread through the eye of the needle.
    • Keep your fingers away from the sharp tip of the needle to avoid injury. If necessary, use a thimble to protect your finger.
    • If you have trouble getting the thread through the eye of the needle, you can lick the tip of the thread. This will tighten the thread fibers and allow easier insertion into the needle.
  3. How To Fix Torn Winter Earmuffs: 3 단계, 이미지 1개 중 1개
    • Pull the thread through the eye of the needle until equal amounts of thread are on each side.
    • This is called a double thread, and it makes the thread stronger. It is not required, but it is helpful.
  4. How To Fix Torn Winter Earmuffs: 4 단계, 이미지 2개 중 1개 How To Fix Torn Winter Earmuffs: 4 단계, 이미지 2개 중 2개
    • Tie a solid knot around the needle to secure the thread, repeating if necessary.
  5. How To Fix Torn Winter Earmuffs: 5 단계, 이미지 2개 중 1개 How To Fix Torn Winter Earmuffs: 5 단계, 이미지 2개 중 2개
    • Using an invisible seam stitch, sew the earmuff onto the headband.
    • For easier visibility, these images show a thread color that contrasts with the earmuffs. Be sure to choose a thread color that matches with your earmuffs.
  6. How To Fix Torn Winter Earmuffs: 6 단계, 이미지 3개 중 1개 How To Fix Torn Winter Earmuffs: 6 단계, 이미지 3개 중 2개 How To Fix Torn Winter Earmuffs: 6 단계, 이미지 3개 중 3개
    • Pull the thread tight and tie a solid knot to secure it on the earmuff.
  7. How To Fix Torn Winter Earmuffs: 7 단계, 이미지 3개 중 1개 How To Fix Torn Winter Earmuffs: 7 단계, 이미지 3개 중 2개 How To Fix Torn Winter Earmuffs: 7 단계, 이미지 3개 중 3개
    • Near the knot, insert the needle and thread into the earmuffs.
    • Pull the needle and thread out of the earmuffs towards yourself.
  8. How To Fix Torn Winter Earmuffs: 8 단계, 이미지 2개 중 1개 How To Fix Torn Winter Earmuffs: 8 단계, 이미지 2개 중 2개
    • Trim the excess thread.
  9. How To Fix Torn Winter Earmuffs: 9 단계, 이미지 2개 중 1개 How To Fix Torn Winter Earmuffs: 9 단계, 이미지 2개 중 2개
    • Locate any additional excess thread.
    • Pull the earmuff fabric gently to tuck the thread inside.
결론
You have now fixed your winter earmuffs. Congratulations!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Violet Ichel
회원 가입일: 11/04/24
187 평판
안내서 1개를 작성함
UC Davis, Team 3-6, Vidal-Chiesa Fall 2024 UC Davis, Team 3-6, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S3G6
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 32
지난 30일: 90
전체 시간: 379
