주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How To Fix Vertical Lines On An iPhone Screen After Replacement
필요한 것
  1. How To Fix Vertical Lines On An iPhone Screen After Replacement, Electro-Static Discharge (ESD): 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Mat
    $24.99
    • ESD is a common culprit behind display malfunction.
    • Ground yourself and your device to discharge any built up static charge before repairing your phone. The best way to do this is to use an anti-static mat and wear an anti-static wrist strap.
  2. How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: 2 단계, 이미지 3개 중 1개 How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: 2 단계, 이미지 3개 중 2개 How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: 2 단계, 이미지 3개 중 3개
    • Check the display connections on the cables and the logic board. Dirt, dust or debris can cause a faulty connection and should be cleaned with a soft brush and high concentration isopropyl alcohol (at least 90%). Inspect the connectors and clean as necessary.
    • Isopropyl alcohol is a mild skin and eye irritant. Use gloves and eye protection while working with isopropyl alcohol.
  3. How To Fix Vertical Lines On An iPhone Screen After Replacement, Damaged IC Connector: 3 단계, 이미지 1개 중 1개
    • The display has an IC that could be damaged. Check particularly on the upper left and right corners. Any signs of damage indicate the part is defective and needs to be replaced with a new one.
결론
Screens are fragilé (it must be Italian)
다른 132명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Matt Zieminski
회원 가입일: 02/23/15
49,749 평판
안내서 28개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,536개를 작성함
9가이드 댓글
i had a same problem so can someone sent me the video so that video will help me a lot thanks
Suman Biswa - 답글 공유
i have 4he same problem, mines worse, soon as i turn it on verticle lines its bad you cannot see any thing only lines.. brand new screen with lcd, its not working!!! any solutions? im thinking of o new logic board…
jubonygill - 답글 공유
I had the same problem when removing and installing an iPhone 6 plus battery. After connecting all four flex cables to the mother board the phone either would not boot up or there were vertical lines on the display. Basics, basics, basics……unplug battery connector. Unplug all four flex cable connectors. Re-attach all four flex cable connectors, then connect battery flex cable. After installing both metal shields and closing the phone it booted up properly and worked just like new. Viola!
bassinbill42 - 답글 공유
Did you have any problems after doing that to your phone? Or does it still have the lines?
sscorpion34 - 공유
How to fix the vertical lines camera on iPhone 6
Renz Mendi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 62
지난 30일: 270
전체 시간: 472,156
