주요 콘텐츠로 건너뛰기
How To Fix a Hole in the Sole of a Shoe
필요한 것
  1. How To Fix a Hole in the Sole of a Shoe, How To Fix a Hole in the Sole of a Shoe: 1 단계, 이미지 1/1
    • To begin, clean the Adidas Gazelles with some water on a towel.
    • Be careful not to use too much water or you could further damage your shoes.
  2. How To Fix a Hole in the Sole of a Shoe: 2 단계, 이미지 1/2 How To Fix a Hole in the Sole of a Shoe: 2 단계, 이미지 2/2
    • Carefully use the utility knife to free the hole of any excess material.
    • Make sure and clear the Gazelles of any debris that that could be stuck under the loose squares of the sole.
  3. How To Fix a Hole in the Sole of a Shoe: 3 단계, 이미지 1/1
    • Use 100 grit sandpaper to roughen the inside surface of the hole.
    • This will help the shoe goo grip the surface of the shoe, and produce a more lasting fix.
  4. How To Fix a Hole in the Sole of a Shoe: 4 단계, 이미지 1/2 How To Fix a Hole in the Sole of a Shoe: 4 단계, 이미지 2/2
    • Apply shoe goo to the inside of the hole in the sole of your Adidas Gazelles.
    • Make sure to apply evenly to avoid making your Gazelles off balance.
    • If there is anywhere else on your Gazelle's sole that could use additional protection, apply shoe goo to those surfaces as well.
  5. How To Fix a Hole in the Sole of a Shoe: 5 단계, 이미지 1/1
    • Take your putty knife and smooth the shoe goo flush to the surface of the sole.
    • Try to spread the shoe goo in one direction to increase surface smoothness.
  6. How To Fix a Hole in the Sole of a Shoe: 6 단계, 이미지 1/1
    • Now place your Gazelles in a safe and clean place to dry for 24 hours.
  7. How To Fix a Hole in the Sole of a Shoe: 7 단계, 이미지 1/1
    • After 24 hours, use 150 grit sandpaper to rub down the surface of your filled hole to create a smooth surface.
결론
Now with the hole repaired your Gazelles are ready for action. With the proper care you can extend their life for many years to come.
다른 10명이 해당 안내서를 완성하였습니다.
Hayden
회원 가입일: 04/09/15
497 평판
안내서 1개 작성함
Cal Poly, Team 28-3, Green Spring 2015 Cal Poly, Team 28-3, Green Spring 2015 회원
CPSU-GREEN-S15S28G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 47
30일 전: 186
전체 시간: 21,223
