주요 콘텐츠로 건너뛰기
How To Fix a Torn Book Page
필요한 것
  1. How To Fix a Torn Book Page, How To Fix a Torn Book Page: 1 단계, 이미지 1개 중 1개
    • Lay out all of the equipment needed for the repair.
  2. How To Fix a Torn Book Page: 2 단계, 이미지 1개 중 1개
    • Place one piece of wax paper behind the torn page.
    • The wax paper is used to protect the other pages from the glue.
  3. How To Fix a Torn Book Page: 3 단계, 이미지 1개 중 1개
    • Be very careful in aligning the torn piece with the page, as realignment after gluing will be difficult.
    • Make sure to align the torn pieces precisely. Placing them too closely or too far apart may create an issue in reading the pages later.
    • Align the torn pieces, so they connect the images/text accurately and neatly.
    • You may use a clamp to hold the torn pieces together to make gluing easier.
  4. How To Fix a Torn Book Page: 4 단계, 이미지 3개 중 1개 How To Fix a Torn Book Page: 4 단계, 이미지 3개 중 2개 How To Fix a Torn Book Page: 4 단계, 이미지 3개 중 3개
    • Do not apply too much glue, only enough to evenly cover the tear between the page and the torn piece.
    • Remove any excess glue to prevent the pages from sticking to the wax paper.
    • Grab the fabric glue and squeeze a line of glue all the way along the crevice (tear).
    • Use a small paintbrush to apply a moderate amount of glue along the edges of the ripped areas.
  5. How To Fix a Torn Book Page: 5 단계, 이미지 1개 중 1개
    • Place the second sheet of wax paper on top of the page you just glued.
    • Be careful when placing the wax paper on top of the wet glue. Moving the wax paper around will make the glue smear.
  6. How To Fix a Torn Book Page: 6 단계, 이미지 1개 중 1개
    • Wrap the closed book with several rubber bands to squeeze and compress during drying time.
  7. How To Fix a Torn Book Page: 7 단계, 이미지 2개 중 1개 How To Fix a Torn Book Page: 7 단계, 이미지 2개 중 2개
    • You can also use several books or other heavy items to add extra weight.
  8. How To Fix a Torn Book Page: 8 단계, 이미지 2개 중 1개 How To Fix a Torn Book Page: 8 단계, 이미지 2개 중 2개
    • Let the glue dry for 6 hours minimum to ensure that it dries completely.
    • Carefully peel the top sheet of wax paper first, and then remove the bottom one afterwards.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Isa Camacho
회원 가입일: 09/16/19
190 평판
안내서 1개를 작성함
2가이드 댓글
Thanks for article!
Alex White - 답글
In the materials list, you state parchment paper. However, in the actual descriptions, you mentioned wax paper. Are both possible to use? What kind of wax paper is recommended? I’m not really clear about the discrepancy.
Joshua Boren - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 65
지난 30일: 321
전체 시간: 14,792
