주요 콘텐츠로 건너뛰기
How To Hem Pants With Double-Sided Fabric Tape
필요한 것
  1. How To Hem Pants With Double-Sided Fabric Tape, How To Hem Pants With Double-Sided Fabric Tape: 1 단계, 이미지 1/1
    • First, you want to try on the pants that need hemming.
  2. How To Hem Pants With Double-Sided Fabric Tape: 2 단계, 이미지 1/1
    • Fold up the pants to the desired length you would like.
  3. How To Hem Pants With Double-Sided Fabric Tape: 3 단계, 이미지 1/1
    • Use a ruler to make sure the length is the same all around.
  4. How To Hem Pants With Double-Sided Fabric Tape: 4 단계, 이미지 1/1
    • Use a washable chalk marker to mark where you want the pant leg to come up to.
  5. How To Hem Pants With Double-Sided Fabric Tape: 5 단계, 이미지 1/1
    • Fold up the pants to the desired length using the chalk line as your guide.
  6. How To Hem Pants With Double-Sided Fabric Tape: 6 단계, 이미지 1/1
    • Use an iron or press to create a fold or crease in the pants to the desired length marked by the chalk.
  7. How To Hem Pants With Double-Sided Fabric Tape: 7 단계, 이미지 1/1
    • Creating a fold or crease will help keep your pant length the same on all sides.
  8. How To Hem Pants With Double-Sided Fabric Tape: 8 단계, 이미지 1/1
    • Place the double-sided fabric tape on the edge of the pant legs.
    • I used a total of 4 - 1/2"x3" strips for each pant leg.
  9. How To Hem Pants With Double-Sided Fabric Tape: 9 단계, 이미지 1/1
    • Press firmly for about 10 seconds on the tape to make sure it sticks to the pant leg.
  10. How To Hem Pants With Double-Sided Fabric Tape: 10 단계, 이미지 1/1
    • Remove the remaining backing of the tape.
  11. How To Hem Pants With Double-Sided Fabric Tape: 11 단계, 이미지 1/1
    • Press firmly on all sides of the pants for about 10 seconds to make sure the tape adheres to all sides.
  12. How To Hem Pants With Double-Sided Fabric Tape: 12 단계, 이미지 1/1
    • Try on the pants one last time to make sure they are the desired length to prevent you from tripping over them.
결론
You don't need a sewing machine to hem a pair of overly long pants.
Allison
회원 가입일: 10/07/23
205 평판
안내서 1개 작성함
Austin Community College, Team 22-7, Watkins Fall 2023 Austin Community College, Team 22-7, Watkins Fall 2023 회원
AUSTINCC-WATKINS-F23S22G7
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 56
전체 시간: 201
