주요 콘텐츠로 건너뛰기
How To Hem Pants With Double-Sided Fabric Tape
필요한 것
  1. How To Hem Pants With Double-Sided Fabric Tape, How To Hem Pants With Double-Sided Fabric Tape: 1 단계, 이미지 1개 중 1개
    • First, you want to try on the pants that need hemming.
  2. How To Hem Pants With Double-Sided Fabric Tape: 2 단계, 이미지 1개 중 1개
    • Fold up the pants to the desired length you would like.
  3. How To Hem Pants With Double-Sided Fabric Tape: 3 단계, 이미지 1개 중 1개
    • Use a ruler to make sure the length is the same all around.
  4. How To Hem Pants With Double-Sided Fabric Tape: 4 단계, 이미지 1개 중 1개
    • Use a washable chalk marker to mark where you want the pant leg to come up to.
  5. How To Hem Pants With Double-Sided Fabric Tape: 5 단계, 이미지 1개 중 1개
    • Fold up the pants to the desired length using the chalk line as your guide.
  6. How To Hem Pants With Double-Sided Fabric Tape: 6 단계, 이미지 1개 중 1개
    • Use an iron or press to create a fold or crease in the pants to the desired length marked by the chalk.
  7. How To Hem Pants With Double-Sided Fabric Tape: 7 단계, 이미지 1개 중 1개
    • Creating a fold or crease will help keep your pant length the same on all sides.
  8. How To Hem Pants With Double-Sided Fabric Tape: 8 단계, 이미지 1개 중 1개
    • Place the double-sided fabric tape on the edge of the pant legs.
    • I used a total of 4 - 1/2"x3" strips for each pant leg.
  9. How To Hem Pants With Double-Sided Fabric Tape: 9 단계, 이미지 1개 중 1개
    • Press firmly for about 10 seconds on the tape to make sure it sticks to the pant leg.
  10. How To Hem Pants With Double-Sided Fabric Tape: 10 단계, 이미지 1개 중 1개
    • Remove the remaining backing of the tape.
  11. How To Hem Pants With Double-Sided Fabric Tape: 11 단계, 이미지 1개 중 1개
    • Press firmly on all sides of the pants for about 10 seconds to make sure the tape adheres to all sides.
  12. How To Hem Pants With Double-Sided Fabric Tape: 12 단계, 이미지 1개 중 1개
    • Try on the pants one last time to make sure they are the desired length to prevent you from tripping over them.
결론
You don't need a sewing machine to hem a pair of overly long pants.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Allison
회원 가입일: 10/07/23
232 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 44
지난 30일: 139
전체 시간: 1,814
