주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How To Install Universal Fit LED Daytime Running Lights
필요한 것
  1. How To Install Universal Fit LED Daytime Running Lights, Philips Style LED Daytime Running Lights Upgrade: 1 단계, 이미지 1개 중 1개
    • Insert the wire into the bracket.
    댓글 쓰기
  2. How To Install Universal Fit LED Daytime Running Lights: 2 단계, 이미지 1개 중 1개
    • Mount the bracket. Since this is universal fit, you can mount it anywhere you'd like.
    댓글 쓰기
  3. How To Install Universal Fit LED Daytime Running Lights: 3 단계, 이미지 1개 중 1개
    • After mounting the bracket, you can lock the LED daytime running light on the bracket.
    댓글 쓰기
  4. How To Install Universal Fit LED Daytime Running Lights: 4 단계, 이미지 2개 중 1개 How To Install Universal Fit LED Daytime Running Lights: 4 단계, 이미지 2개 중 2개
    • Connect the wires and route the wires up and near the fuse box.
    • Use zip ties to tie the wire along the bumper.
    댓글 쓰기
  5. How To Install Universal Fit LED Daytime Running Lights: 5 단계, 이미지 2개 중 1개 How To Install Universal Fit LED Daytime Running Lights: 5 단계, 이미지 2개 중 2개
    • Find the ACC in your fuse box and tap the red wire there.
    • You can find the ACC location using an electronic meter by clamping the black wire to the battery negative or ground.
    • When you find ACC, tap the red wires to the blade of the fuse and insert it back.
    댓글 쓰기
  6. How To Install Universal Fit LED Daytime Running Lights: 6 단계, 이미지 1개 중 1개
    • Tap the black wire to battery negative.
    댓글 쓰기
  7. How To Install Universal Fit LED Daytime Running Lights: 7 단계, 이미지 3개 중 1개 How To Install Universal Fit LED Daytime Running Lights: 7 단계, 이미지 3개 중 2개 How To Install Universal Fit LED Daytime Running Lights: 7 단계, 이미지 3개 중 3개
    • Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights.
    댓글 쓰기
결론
As you can see, installation isn't complicated and if you follow the directions accordingly, you'll be on your way to new LED daytime running lights in no time.
취소: 해당 안내서를 완성하지 않았습니다.
다른 21명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eric Wu
회원 가입일: 01/21/15
3,600 평판
안내서 23개를 작성함
11가이드 댓글
Useful information shared. Thanks for giving us nice info. Fantastic walk through. I appreciate this post and here is my link
http://optixautolabs.com/
Calvin Macaraeg - 답글 공유
Useful info. Thanks
grant.edson - 답글 공유
great information and pictures, just one thing, what size of fuse should I use for connection in fuse box.
steve finlayson - 답글 공유
UK road/MOT law states you must 60% dim or better still, make DRL’s turn off when headlights are turned on … stop advertising fake information Phillips and start stating some facts for a change
i cry when i wii - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 23
지난 30일: 112
전체 시간: 96,578
