주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How To Install Universal LED Cab Roof Lights For A Truck
필요한 것
    1. How To Install Universal LED Cab Roof Lights For A Truck, Remove the truck interior front map lamps: 1 단계, 이미지 3개 중 1개 How To Install Universal LED Cab Roof Lights For A Truck, Remove the truck interior front map lamps: 1 단계, 이미지 3개 중 2개 How To Install Universal LED Cab Roof Lights For A Truck, Remove the truck interior front map lamps: 1 단계, 이미지 3개 중 3개
      • There are a couple ways you can power up this LED. You have the choice of adding a switch or just using the truck's interior light switch. For demonstration purposes, we are using the truck's interior lights to power up the entire assembly.
      • Expose the wires by removing the entire front map light assembly.
      댓글 쓰기
    2. How To Install Universal LED Cab Roof Lights For A Truck, Do the measurement on the cab roof: 2 단계, 이미지 3개 중 1개 How To Install Universal LED Cab Roof Lights For A Truck, Do the measurement on the cab roof: 2 단계, 이미지 3개 중 2개 How To Install Universal LED Cab Roof Lights For A Truck, Do the measurement on the cab roof: 2 단계, 이미지 3개 중 3개
      • Get up to the roof of your truck to measure where you're going to install these LED cab roof lights. You can use a dry erase marker to mark all the points where you will be drilling into the roof.
      댓글 쓰기
    3. How To Install Universal LED Cab Roof Lights For A Truck, Drill holes: 3 단계, 이미지 1개 중 1개
      댓글 쓰기
    4. How To Install Universal LED Cab Roof Lights For A Truck, Mount the LED cab roof lamps: 4 단계, 이미지 2개 중 1개 How To Install Universal LED Cab Roof Lights For A Truck, Mount the LED cab roof lamps: 4 단계, 이미지 2개 중 2개
      • Use a screwdriver and attach the screws at the front and the rear of each LED roof lamp to permanently mount it.
      댓글 쓰기
    5. How To Install Universal LED Cab Roof Lights For A Truck, Wiring: 5 단계, 이미지 3개 중 1개 How To Install Universal LED Cab Roof Lights For A Truck, Wiring: 5 단계, 이미지 3개 중 2개 How To Install Universal LED Cab Roof Lights For A Truck, Wiring: 5 단계, 이미지 3개 중 3개
      • Wire up the LED lights in parallel. Use some electrical tape to secure the connections. Route the wires through the front map light assembly to complete the wiring portion.
      댓글 쓰기
    6. How To Install Universal LED Cab Roof Lights For A Truck, Enjoy your new LED cab roof marker lights: 6 단계, 이미지 2개 중 1개 How To Install Universal LED Cab Roof Lights For A Truck, Enjoy your new LED cab roof marker lights: 6 단계, 이미지 2개 중 2개
      • Test everything and enjoy your new LED cab roof light.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Eric Wu
회원 가입일: 01/21/15
3,600 평판
안내서 23개를 작성함
1가이드 댓글
When you route the wires through the front map assembly, how exactly do you hook up the wires to the exposed map lights
Luke - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 97
전체 시간: 17,323
