이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Carefully insert your Mac OEM SSD as shown, with the golden contact pads below the connector pins facing upward.
Use a Phillips driver to install the 4.5 mm screw securing the bottom of the SSD.
Place the port cover plate onto the end of the enclosure, aligning the USB-C port with its cutout.
Use a Phillips driver to install the two 8 mm screws onto the end of the enclosure.
The drive is now ready to be connected to your computer with either of the included USB cables.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 4개
Danke für das Teilen. Es wäre besser, wenn Sie ein zusätzliches Video-Tutorial haben. bloxorz
Is there any driver that needs installed for this? My MacBook Pro, a MacBook Air, and a Windows machine do not recognize any USB storage device is being connected at all. Nothing shows up with Disk Utility.
Installed an original MacBook Air 11" Early 2014 SSD drive - doesn't work at all! Waisted €119,95
