소개
This guide shows how to perform general maintenance on your cooker hood to improve its efficiency and prolong its lifespan. Regular upkeep ensures that grease and debris do not obstruct the motor and filter, which can reduce performance and cause damage over time. Removing buildup safeguards against electrical issues and unpleasant odors, letting your cooker hood operate at its best.
필요한 것
2 단계 Remove the filter and panels
Detach the grease filter if it is still in place and set it aside.
Unscrew or unclip any external panels to expose the interior components.
3 단계 Disassemble the hood
Locate and remove screws or clips securing the hood interior and lamp assembly.
Lift away plastic or metal covers to gain access to the motor housing.
Detach the lamp unit gently if present to protect the bulb and wiring.
4 단계 Separate electrical parts
Remove any electrical components or cable holders from the casing.
Set aside circuit boards or switches to keep them dry during cleaning.
5 단계 Degrease the casing
Apply a degreasing solution liberally to all hood surfaces and let it soak for approximately 5-6 hours.
Rinse or wipe away any loosened buildup after soaking.
6 단계 Clean the motor assembly
Use a suitable solvent with a cloth or brush to remove built-up grease.
Disassemble the motor if needed by removing its securing bolts with care.
7 단계 Wash the removed parts
Soak metal panels, fan covers, and removable parts in hot water or a dishwasher.
Dry all components thoroughly before moving on to reassembly.
8 단계 Reassemble the motor
Lubricate bushings and the motor shaft lightly with appropriate machine oil.
Realign the rotor, stator, and washers, ensuring each part is in its original place.
Tighten bolts or nuts evenly and check for smooth rotation without friction.
9 단계 Reassemble the hood
Repair or reinforce any cracked lamp housing with suitable materials (duck tape, double-sided tape, aluminum foil).
Reattach the motor and all electrical components in reverse order of removal.
Reinstall the grease filter and secure all casing panels firmly.
Maintaining your cooker hood keeps it operating at peak performance and extends its service life. Clean, lubricate, and inspect regularly to prevent excessive buildup and electrical issues. With routine care, the hood effectively removes odors and grease, promoting a safer and more pleasant cooking environment.
다른 한 분이 해당 안내서를 완성하였습니다.
