주요 콘텐츠로 건너뛰기
How To Patch a Hole in Umbrella Fabric
필요한 것
  1. How To Patch a Hole in Umbrella Fabric, Fabric: 1 단계, 이미지 1/1
    • Remove the fabric from the extender arms of your umbrella.
    • This allows you to more easily work with the torn area, as the fabric won't be held tightly.
  2. How To Patch a Hole in Umbrella Fabric: 2 단계, 이미지 1/1
    • Sew the tear together from the back side of the umbrella using your needle and nylon thread.
    • Be sure to use a thin gauge nylon thread, as cotton threads will soak through and cause leaks in your canopy.
  3. How To Patch a Hole in Umbrella Fabric: 3 단계, 이미지 1/1
    • Cut your patch to an appropriate size relative to the tear.
    • The size of your patch should be big enough to completely cover the tear, with around an inch of additional material on all sides.
  4. How To Patch a Hole in Umbrella Fabric: 4 단계, 이미지 1/1
    • Apply your fabric glue to the backside of your patch material.
  5. How To Patch a Hole in Umbrella Fabric: 5 단계, 이미지 1/1
    • Lay the torn area of the fabric on a flat surface.
  6. How To Patch a Hole in Umbrella Fabric: 6 단계, 이미지 1/1
    • Apply your patch squarely over the torn fabric.
결론
To reassemble your umbrella, reattach the fabric to the rivets that you disconnected it from.
Brandon Hillert
회원 가입일: 10/04/20
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 137
30일 전: 673
전체 시간: 14,337
