주요 콘텐츠로 건너뛰기
How To Patch a Hole in Umbrella Fabric
필요한 것
  1. How To Patch a Hole in Umbrella Fabric, Fabric: 1 단계, 이미지 1개 중 1개
    • Remove the fabric from the extender arms of your umbrella.
    • This allows you to more easily work with the torn area, as the fabric won't be held tightly.
  2. How To Patch a Hole in Umbrella Fabric: 2 단계, 이미지 1개 중 1개
    • Sew the tear together from the back side of the umbrella using your needle and nylon thread.
    • Be sure to use a thin gauge nylon thread, as cotton threads will soak through and cause leaks in your canopy.
  3. How To Patch a Hole in Umbrella Fabric: 3 단계, 이미지 1개 중 1개
    • Cut your patch to an appropriate size relative to the tear.
    • The size of your patch should be big enough to completely cover the tear, with around an inch of additional material on all sides.
  4. How To Patch a Hole in Umbrella Fabric: 4 단계, 이미지 1개 중 1개
    • Apply your fabric glue to the backside of your patch material.
  5. How To Patch a Hole in Umbrella Fabric: 5 단계, 이미지 1개 중 1개
    • Lay the torn area of the fabric on a flat surface.
  6. How To Patch a Hole in Umbrella Fabric: 6 단계, 이미지 1개 중 1개
    • Apply your patch squarely over the torn fabric.
결론
To reassemble your umbrella, reattach the fabric to the rivets that you disconnected it from.
작성자
2다른 기여자 명과 함께
Brandon Hillert
회원 가입일: 10/04/20
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 145
전체 시간: 19,476
