주요 콘텐츠로 건너뛰기
How To Re-String A Hoodie
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. How To Re-String A Hoodie, How To Re-String A Hoodie: 1 단계, 이미지 1/2 How To Re-String A Hoodie, How To Re-String A Hoodie: 1 단계, 이미지 2/2
    • Uncoil the wire coat hanger into a straight line.
  2. How To Re-String A Hoodie: 2 단계, 이미지 1/3 How To Re-String A Hoodie: 2 단계, 이미지 2/3 How To Re-String A Hoodie: 2 단계, 이미지 3/3
    • Tape the end of the uncoiled coat hanger to one end of your sweatshirt string.
    • Make sure the clothes hanger is securely taped to ensure that the string doesn't detach during the re-stringing process.
    • When taping, make sure no adhesive is felt over the outside of the apparatus. This will make the re-stringing process easier because the tape won't be sticking to the sweatshirt.
  3. How To Re-String A Hoodie: 3 단계, 이미지 1/1
    • Insert the wire and string apparatus into the left opening of the hoodie.
  4. How To Re-String A Hoodie: 4 단계, 이미지 1/1
    • Feed the wire through the hoodie until it reaches the top of the hood.
  5. How To Re-String A Hoodie: 5 단계, 이미지 1/2 How To Re-String A Hoodie: 5 단계, 이미지 2/2
    • Curve the wire to the right so that the wire can follow the curve of the hood.
  6. How To Re-String A Hoodie: 6 단계, 이미지 1/2 How To Re-String A Hoodie: 6 단계, 이미지 2/2
    • Continue feeding the wire through the hood towards the other opening of the hoodie.
    • Pull the wire and string out of the opening.
  7. How To Re-String A Hoodie: 7 단계, 이미지 1/2 How To Re-String A Hoodie: 7 단계, 이미지 2/2
    • Remove the tape from the end of the wire and string.
  8. How To Re-String A Hoodie: 8 단계, 이미지 1/2 How To Re-String A Hoodie: 8 단계, 이미지 2/2
    • Remove the wire from the hoodie by pushing the left end of the wire through the hoodie, while pulling the right end out.
  9. How To Re-String A Hoodie: 9 단계, 이미지 1/1
    • Tie each end of the string in a knot to prevent the string from coming out of the hoodie.
결론
Congratulations on restringing your hoodie!
다른 4명이 해당 안내서를 완성하였습니다.
Ashley
회원 가입일: 02/24/15
267 평판
안내서 1개 작성함
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015 회원
CPSU-GREEN-W15S23G1
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
my apple iphone 4 is disabled connect to itunes
Ali Hemmati - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 272
