주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How To Remove Hardened Masking Tape From Car Paint
필요한 것
  1. How To Remove Hardened Masking Tape From Car Paint, How To Remove Hardened Masking Tape From Car Paint: 1 단계, 이미지 1개 중 1개
    • Goo Gone can be harmful to skin after prolonged exposure so be sure to have your gloves on during this entire process.
    • Spray the paper towel 2 times with the Goo Gone.
    • Be sure to turn the nozzle into the "on" position.
    댓글 쓰기
  2. How To Remove Hardened Masking Tape From Car Paint: 2 단계, 이미지 1개 중 1개
    • Press the wet paper towel against the hardened tape for about 30 seconds.
    • This will soften the tape.
    댓글 쓰기
  3. How To Remove Hardened Masking Tape From Car Paint: 3 단계, 이미지 2개 중 1개 How To Remove Hardened Masking Tape From Car Paint: 3 단계, 이미지 2개 중 2개
    • Aggressively scrub the tape for about 10 seconds.
    댓글 쓰기
  4. How To Remove Hardened Masking Tape From Car Paint: 4 단계, 이미지 2개 중 1개 How To Remove Hardened Masking Tape From Car Paint: 4 단계, 이미지 2개 중 2개
    • Repeat steps 2 and 3 until all of the adhesive residue has been removed.
    댓글 쓰기
결론
Now that you have successfully removed the tape for your car, it is recommended that you wash your car to get rid of the Goo Gone remnants. Who doesn't love a clean car, anyway?
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jami Hahn
회원 가입일: 02/23/15
371 평판
안내서 1개를 작성함
Cal Poly, Team 12-4, Green Winter 2015 Cal Poly, Team 12-4, Green Winter 2015 회원
CPSU-GREEN-W15S12G4
5 회원들
안내서 10개를 작성함
1가이드 댓글
This masking tape has been on the side of this old VW for years will googone still take off several layers of it ?
Randy Verburg - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 16
지난 30일: 95
전체 시간: 38,157
