주요 콘텐츠로 건너뛰기
How To Remove Rust From Old Tools
필요한 것
  1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: 1 단계, 이미지 1/2 How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: 1 단계, 이미지 2/2
    • Removing rust generally isn't dangerous, but it's pretty messy.
    • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
    • Consider also wearing protective gloves.
    • Place your tool on the towels.
  2. How To Remove Rust From Old Tools: 2 단계, 이미지 1/2 How To Remove Rust From Old Tools: 2 단계, 이미지 2/2
    • Spray the rusty areas of the tool with a generous amount of WD-40.
  3. How To Remove Rust From Old Tools: 3 단계, 이미지 1/3 How To Remove Rust From Old Tools: 3 단계, 이미지 2/3 How To Remove Rust From Old Tools: 3 단계, 이미지 3/3
    • Use a scouring pad to thoroughly scrub the tool.
    • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
  4. How To Remove Rust From Old Tools: 4 단계, 이미지 1/3 How To Remove Rust From Old Tools: 4 단계, 이미지 2/3 How To Remove Rust From Old Tools: 4 단계, 이미지 3/3
    • Use a paper towel to wipe away the excess grime and WD-40.
  5. How To Remove Rust From Old Tools: 5 단계, 이미지 1/1
    • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
    • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
    you need to use a zoom in picture in step 4 for step 5!
    stephen harrison - 답글
결론
다른 7명이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
89,892 평판
안내서 89개 작성하였습니다
댓글 2개
Apple cider vinegar removes rust well. Try it.
Michael Jucker - 답글
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 41
30일 전: 97
전체 시간: 4,345
