주요 콘텐츠로 건너뛰기
How To Remove Scratches From A Hardwood Floor
필요한 것
  1. How To Remove Scratches From A Hardwood Floor, How To Remove Scratches From A Hardwood Floor: 1 단계, 이미지 1개 중 1개
    • Identify the scratch you would like to repair.
  2. How To Remove Scratches From A Hardwood Floor: 2 단계, 이미지 1개 중 1개
    • Using a hardwood cleaner and a clean cloth, wipe the area down to remove any dirt or debris.
  3. How To Remove Scratches From A Hardwood Floor: 3 단계, 이미지 1개 중 1개
    • Using painter's tape, isolate the area of the scratch.
    • Try to keep the tape as close to the scratch as possible.
  4. How To Remove Scratches From A Hardwood Floor: 4 단계, 이미지 1개 중 1개
    • Apply wood filler into the scratch using a putty knife.
    • Try to make sure every part of the scratch has been filled. Too much is better than too little here.
  5. How To Remove Scratches From A Hardwood Floor: 5 단계, 이미지 2개 중 1개 How To Remove Scratches From A Hardwood Floor: 5 단계, 이미지 2개 중 2개
    • After drying for 10-15 minutes, sand the area down until the wood filler is level with the rest of the floor.
  6. How To Remove Scratches From A Hardwood Floor: 6 단계, 이미지 1개 중 1개
    • Find a stain pen that will match as close as possible to the finish of your floor. Apply this stain to the wood filler and let it dry.
  7. How To Remove Scratches From A Hardwood Floor: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • After drying completely, apply some wipe on polyurethane to a microfiber cloth or towel.
    • Buff the area with the cloth.
    • This will ensure the sanded area will regain it's shine and blend in with the rest of the floor.
  8. How To Remove Scratches From A Hardwood Floor: 8 단계, 이미지 1개 중 1개
    • After applying the wipe on polyurethane, your scratch should now be blended in with the rest of the floor.
결론
The scratch will hardly be noticeable after this repair. Depending on the depth of the scratch, it is possible this fix will not make the floor look good as new. For very deep scratches the only remedy may be to replace the floor board.
작성자
2다른 기여자 명과 함께
Ryan Nicasio
회원 가입일: 01/21/21
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 60
전체 시간: 1,439
