주요 콘텐츠로 건너뛰기
How To Repair A Couch Cushion
필요한 것
  1. How To Repair A Couch Cushion, How To Repair A Couch Cushion: 1 단계, 이미지 1개 중 1개
    • Apply a thin layer of the anti-fray glue to both edges of the rip. Let it dry completely.
  2. How To Repair A Couch Cushion: 2 단계, 이미지 1개 중 1개
    • Fold the edges of the fabric over to make a clean edge and hide any fraying.
    • Crease the fold with your fingers.
  3. How To Repair A Couch Cushion: 3 단계, 이미지 1개 중 1개
    • Cut the upholstery thread to a length appropriate for the size of your rip.
    • The thread should match the color of the fabric as closely as possible.
    • Thread the needle and tie a double knot at the end.
  4. How To Repair A Couch Cushion: 4 단계, 이미지 2개 중 1개 How To Repair A Couch Cushion: 4 단계, 이미지 2개 중 2개
    • Hold the two edges of the rip together
    • Begin sewing ¾ of an inch from where the rip begins.
    • You might want to use a pin to hold the edges together while you sew
  5. How To Repair A Couch Cushion: 5 단계, 이미지 3개 중 1개 How To Repair A Couch Cushion: 5 단계, 이미지 3개 중 2개 How To Repair A Couch Cushion: 5 단계, 이미지 3개 중 3개
    • Continue sewing until you are past the rip. Knot and cut the excess thread.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alexis
회원 가입일: 02/24/15
227 평판
안내서 1개를 작성함
Cal Poly, Team 24-2, Green Winter 2015 Cal Poly, Team 24-2, Green Winter 2015 회원
CPSU-GREEN-W15S24G2
4 회원들
안내서 4개를 작성함
1가이드 댓글
Have you seen this product? "fixmytear". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
https://www.amazon.com/Fixmytear-Magic-R...
https://www.amazon.com/fixmytear-Magic-R...
bobhunter50023 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 17
전체 시간: 17,789
