주요 콘텐츠로 건너뛰기
How To Repair A Paint Stained Baseboard
필요한 것
  1. How To Repair A Paint Stained Baseboard, How To Repair A Paint Stained Baseboard: 1 단계, 이미지 3개 중 1개 How To Repair A Paint Stained Baseboard, How To Repair A Paint Stained Baseboard: 1 단계, 이미지 3개 중 2개 How To Repair A Paint Stained Baseboard, How To Repair A Paint Stained Baseboard: 1 단계, 이미지 3개 중 3개
    • Lay down a drop cloth or plastic sheeting to protect the floor from dust and paint.
    • Use painter's tape to mask off the edges where the baseboard meets the wall and the floor to prevent damage to other surfaces.
  2. How To Repair A Paint Stained Baseboard: 2 단계, 이미지 3개 중 1개 How To Repair A Paint Stained Baseboard: 2 단계, 이미지 3개 중 2개 How To Repair A Paint Stained Baseboard: 2 단계, 이미지 3개 중 3개
    • Clean the baseboard with a solution of mild detergent and a clean wet cloth.
    • For stubborn stains or greasy areas, use wood cleaner or mineral spirits.
    • Wipe the baseboard dry with a clean cloth.
  3. How To Repair A Paint Stained Baseboard: 3 단계, 이미지 3개 중 1개 How To Repair A Paint Stained Baseboard: 3 단계, 이미지 3개 중 2개 How To Repair A Paint Stained Baseboard: 3 단계, 이미지 3개 중 3개
    • If the paint stain is raised or thick, use a putty knife or paint scraper to gently scrape off as much of the old paint as possible without damaging the wood underneath.
    • If using rubber gloves, put them on after using the paint scraper or putty knife.
    • Use 120-grit sandpaper to sand the stained area, smoothing out any rough edges and removing the remaining paint.
    • Sand in the direction of the wood grain.
  4. How To Repair A Paint Stained Baseboard: 4 단계, 이미지 3개 중 1개 How To Repair A Paint Stained Baseboard: 4 단계, 이미지 3개 중 2개 How To Repair A Paint Stained Baseboard: 4 단계, 이미지 3개 중 3개
    • Use 220-grit sandpaper to smooth the area further, blending it seamlessly with the surrounding surface.
    • This will help remove any fine scratches caused by the coarser sandpaper.
    • If the scraping or sanding has created any dents or gouges in the baseboard, apply wood filler with a putty knife to fill these areas.
    • Allow the wood filler to dry according to the manufacturer’s instructions, then sand it smooth with 220-grit sandpaper.
  5. How To Repair A Paint Stained Baseboard: 5 단계, 이미지 3개 중 1개 How To Repair A Paint Stained Baseboard: 5 단계, 이미지 3개 중 2개 How To Repair A Paint Stained Baseboard: 5 단계, 이미지 3개 중 3개
    • Use a paint brush to apply a coat of primer to the sanded and repaired area to ensure the paint adheres well.
    • Use a small paintbrush to apply paint to the repaired area, ensuring an even coat. Select a paint that matches the existing color of the baseboard for a seamless finish.
    • Apply a thin, even coat and let it dry completely before applying additional coats if necessary.
  6. How To Repair A Paint Stained Baseboard: 6 단계, 이미지 3개 중 1개 How To Repair A Paint Stained Baseboard: 6 단계, 이미지 3개 중 2개 How To Repair A Paint Stained Baseboard: 6 단계, 이미지 3개 중 3개
    • Once the paint is dry, carefully remove the painter’s tape.
    • Pull the tape at a 45-degree angle to avoid pulling off any paint.
  7. How To Repair A Paint Stained Baseboard: 7 단계, 이미지 3개 중 1개 How To Repair A Paint Stained Baseboard: 7 단계, 이미지 3개 중 2개 How To Repair A Paint Stained Baseboard: 7 단계, 이미지 3개 중 3개
    • Clean your tools with appropriate solvents (water for latex paint, mineral spirits for oil-based paint).
    • Dispose of any used materials properly.
  8. How To Repair A Paint Stained Baseboard: 8 단계, 이미지 3개 중 1개 How To Repair A Paint Stained Baseboard: 8 단계, 이미지 3개 중 2개 How To Repair A Paint Stained Baseboard: 8 단계, 이미지 3개 중 3개
    • Check the repaired area to ensure it blends seamlessly with the rest of the baseboard.
    • Touch up any imperfections as needed.
결론
작성자
1다른 기여자 명과 함께
Bree Cooper
회원 가입일: 09/27/24
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 25
전체 시간: 282
