주요 콘텐츠로 건너뛰기
How To Repair A Rip In Chiffon Fabric
필요한 것
  1. How To Repair A Rip In Chiffon Fabric, How To Repair A Rip In Chiffon Fabric: 1 단계, 이미지 1개 중 1개
    • Locate the rip in the fabric.
  2. How To Repair A Rip In Chiffon Fabric: 2 단계, 이미지 1개 중 1개
    • Trim off any fraying at the tear.
    • Fold the fabric in half at the tear and cut off the fraying. This makes it easier to clip the smaller frayed fibers as well.
  3. How To Repair A Rip In Chiffon Fabric: 3 단계, 이미지 1개 중 1개
    • Fold the fabric in half at the rip so that the raw edges are right side together.
  4. How To Repair A Rip In Chiffon Fabric: 4 단계, 이미지 1개 중 1개
    • Find a permanent fabric adhesive.
  5. How To Repair A Rip In Chiffon Fabric: 5 단계, 이미지 1개 중 1개
    • Carefully apply the adhesive to the raw edges.
  6. How To Repair A Rip In Chiffon Fabric: 6 단계, 이미지 1개 중 1개
    • Keep the edges together until almost dry.
  7. How To Repair A Rip In Chiffon Fabric: 7 단계, 이미지 1개 중 1개
    • Then lay the cloth flat and push the edges together to make sure the ends stay together.
    • Let the adhesive dry completely.
    • At this point, if your tear/repair is large, you can find a patch that can cover the repair and glue it on.
    • Avoid ironing on the patch. This may cause even more damage to fabric as this material is already very delicate.
결론
Now the damage done to your fabric should be contained and the material should be restored to working order. Hope this helped!
작성자
1다른 기여자 명과 함께
Manasa Dintakurthi
회원 가입일: 10/08/20
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 51
지난 30일: 227
전체 시간: 16,321
