소개
This guide shows how to replace a worn or broken clutch in your blender, ensuring you can keep mixing efficiently. You should perform this procedure when you hear grinding noises or see damage on the coupler teeth. Replacing and lubricating the clutch can prevent further damage and extend the life of your blender.
필요한 것
2 단계 Remove the housing
Detach any removable container or lid from the top of the blender and set it aside.
Flip the motor base to access the screws securing the housing.
Use a Torx driver to remove the screws and gently lift the housing off the motor unit.
3 단계 Remove the old clutch
Locate the notch on the rotor and insert a flathead screwdriver to block the shaft from turning.
Grip the old clutch and rotate it counterclockwise to loosen and remove it from the rotor.
Check if your blender uses a slip-on type that pulls off rather than unscrews.
4 단계 Lubricate the bushings
Apply a small amount of machine oil to the bushings around the rotor shaft.
5 단계 Install the new clutch
Thread or press the new clutch onto the rotor shaft in the correct orientation.
Block the rotor with a screwdriver and hand-tighten the clutch to secure it.
6 단계 Reassemble the housing
Align the housing with the motor base and lower it into place.
Secure the housing with the Torx screws and verify it sits flush.
Plug in the blender briefly to verify that the new clutch engages properly.
7 단계 Check function and maintenance
Clean the blender housing regularly to prevent debris from causing clutch wear.
Regularly inspect the clutch for wear or damage, especially if you blend heavy ingredients often. Lubricating the bushings and securing the blender housing will help maintain optimal performance. A properly installed and well-maintained clutch ensures your blender serves you reliably for many more mixes and blends.
