주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
동영상 개요
  1. How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the SIM card tray.: 1 단계, 이미지 1/1
    • Power off the Galaxy S6 Edge Plus and remove the SIM card tray.
  2. How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the back  cover.: 2 단계, 이미지 1/3 How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the back  cover.: 2 단계, 이미지 2/3 How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the back  cover.: 2 단계, 이미지 3/3
    • Heat up to soften the adhesive around the back cover.
    • Pull up a gap to insert the prying tool and a poker card.
    • Run the poker card and case opening tool around the edges to separate the back cover.
  3. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the rear housing.: 3 단계, 이미지 1/2 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the rear housing.: 3 단계, 이미지 2/2
    • Undo the 18 screws in the rear housing.
    • Pull up the rear housing from LCD assembly with frame.
  4. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the motherboard.: 4 단계, 이미지 1/3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the motherboard.: 4 단계, 이미지 2/3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the motherboard.: 4 단계, 이미지 3/3
    • Pry up the screen flex connector, battery flex connector, ear speaker flex connector and proximity sensor flex connector.
    • Pry up the motherboard and turn it upside down to release the connector behind.
    • Pry up the connectors on the motherboard to release the front facing and rear facing camera if necessary.
  5. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the battery. (Be extremely patient and gentle.): 5 단계, 이미지 1/3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the battery. (Be extremely patient and gentle.): 5 단계, 이미지 2/3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the battery. (Be extremely patient and gentle.): 5 단계, 이미지 3/3
    • Pry up around the edges of battery as there're two main adhesive sticker underneath.
    • Insert the Spudger to pry up the adhesive.
    • Tear the battery by hands.
  6. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the small parts assembled in the front frame.: 6 단계, 이미지 1/3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the small parts assembled in the front frame.: 6 단계, 이미지 2/3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the small parts assembled in the front frame.: 6 단계, 이미지 3/3
    • Pry up to release the proximity sensor module.
    • Pry up to release the ear speaker.
    • Pry up to release the vibrating motor.
  7. How To Tear Down Samsung Galaxy S6 Edge Plus, Galaxy S6 Edge Plus charging port assembly.: 7 단계, 이미지 1/1
    • As stated by the video, the charging port flex ribbon assembly cannot be removed until the front glass is torn down as it’s assembled with the navigator flex in between the glass and LCD.
Mandy
회원 가입일: 12/05/14
9,518 평판
안내서 9개 작성하였습니다
댓글 17개
Hi there.
Is this a good way to replace the frame around the camera? I dropped it and chipped it slightly and since the phone is less than 2 months old for me, it is kind of bothering me.
I guess my main concern is, once I do this, is it going to go back together as good as new? I'll probably only need to remove the back cover yeah?
Thanks in advance!
Luke Carr - 답글
hello, you will need to remove the back cover glass b4 you replace the camera lens and holder. replace processing is simple a hot air gun will help a lot.
check here: https://www.amazon.com/dp/B01M3PL8E8
ggmall -
Great video! Thank you for your time to help us out!
Bob Zak - 답글
Every one of these I have seen has a lot of adhesive near the home button which makes the screen coming out much harder then any video or tutorial I have seen online showing.
Jody Billings - 답글
anybody have measurements on the battery ceiling? Does this model have similar issues as the note 7 with no padding to account for battery expansion?
Noah - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 56,672
