주요 콘텐츠로 건너뛰기
How To Transfer Content To Your New 3DS XL
필요한 것
동영상 개요
  1. How To Transfer Content To Your New 3DS XL, How To Transfer Content To Your New 3DS XL: 1 단계, 이미지 1/1
    • Start by removing the stylus from the frame of the New 3DS XL.
  2. How To Transfer Content To Your New 3DS XL: 2 단계, 이미지 1/3 How To Transfer Content To Your New 3DS XL: 2 단계, 이미지 2/3 How To Transfer Content To Your New 3DS XL: 2 단계, 이미지 3/3
    • Loosen the two captive Phillips #1 screws on the back of the device.
    • These captive screws will conveniently stay in the rear cover, so don't try to remove them.
    • Prying from the thumb slots on each side, pull the rear panel off the back of the device.
  3. How To Transfer Content To Your New 3DS XL: 3 단계, 이미지 1/1
    • Press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Use a PC to copy the data from the source SD card to the New 3DS XL microSD card.
    • You may need a micro SD to SD adapter.
    • For reassembly, push the microSD card into the slot until it clicks in place.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
89,935 평판
안내서 89개 작성하였습니다
댓글 한 개
Can anyone who's actually tried the text portion of this guide confirm whether it works? As I understand it, all the data on a 3ds is encrypted with a console-specific key (movable.sed) to prevent exactly this. If it actually worked like this, wouldn't it defeat copy protection almost entirely since any o3ds encrypted ROM could just be copied as-is to a n3ds and run normally?
darth mango - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 19
30일 전: 74
전체 시간: 5,740
