주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How To True A Bicycle Wheel
필요한 것
동영상 개요
  1. How To True A Bicycle Wheel, How To True A Bicycle Wheel: 1 단계, 이미지 1개 중 1개
    • Put the rim and align into the truing stand.
  2. How To True A Bicycle Wheel: 2 단계, 이미지 1개 중 1개
    • Second, grab lubricant.
  3. How To True A Bicycle Wheel: 3 단계, 이미지 1개 중 1개
    • Notice how each nipple is void of lube. In this step add the lube to each individual nipple.
  4. How To True A Bicycle Wheel: 4 단계, 이미지 1개 중 1개
    • Once you have completed the previous task, loosen the truing knob.
    • This will make the truing arms open.
    • Give it a spin! The centrifical force lubes up the threads, making it easier to begin truing.
    • Notice the spoke wrenches; they will be required in our next step.
  5. How To True A Bicycle Wheel: 5 단계, 이미지 1개 중 1개
    • Use the truing knob to determine how fine the truing arms (red) need to be. In this case, I am truing finely down to the millimeter.
  6. How To True A Bicycle Wheel: 6 단계, 이미지 1개 중 1개
    • Here the spoke tool (red) will be needed. After giving it a spin, I noticed that it deviated far too much to the left. You will know this by hearing which side scrapes against the truing arm. (orange)
    • Use the spoke wrench (red) to tighten the spokes (yellow). It is good practice to tighten the spoke before and after on the side that needs truing.
    • Lastly, keep truing tire until the range of deviation is good to you. This process for a "quick-fix" can be as little as 30min-1 hour.
    • Experienced cyclists may vary from days to weeks to completely true their tire.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Elijah W
회원 가입일: 10/16/23
187 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 26
전체 시간: 361
