주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Can iPhone 11 Pro possibly be turned into iPhone 11 Pro Max? It is actually theoretically possible. With pins of the two phones’ display connector and touch connector functioning almost the same, we can turn an iPhone 11 Pro into an iPhone 11 Pro Max by changing board ID resistors.
동영상 개요
  1. iPhone 11 Pro VS iPhone 11 Pro Max
    • iPhone 11 Pro VS iPhone 11 Pro Max
    • iPhone 11 Pro comes with a 5.80-inch touchscreen display.
    • iPhone 11 Pro Max comes with a 6.50-inch touchscreen display.
  2. What will happen when we connect the iPhone 11 Pro Max screen with the housing of iPhone 11 Pro directly?
    • What will happen when we connect the iPhone 11 Pro Max screen with the housing of iPhone 11 Pro directly?
  3. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  4. Compare the motherboard of iPhone 11 Pro and that of iPhone 11 Pro Max. The component array of the two is almost the same. There is one more board ID resistor next to CPU on iPhone 11 Pro.
    • Compare the motherboard of iPhone 11 Pro and that of iPhone 11 Pro Max. The component array of the two is almost the same. There is one more board ID resistor next to CPU on iPhone 11 Pro.
    • All we need to do is remove the extra board ID resistor.
  5. We can see on the interface of 3uTools that the phone has entered DFU mode. And the phone has been turned into iPhone 11 Pro Max. We can write firmware of iPhone 11 Pro Max to the phone.
    • We can see on the interface of 3uTools that the phone has entered DFU mode. And the phone has been turned into iPhone 11 Pro Max. We can write firmware of iPhone 11 Pro Max to the phone.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Phryne
회원 가입일: 2019년 11월 17일
8,008 평판
안내서 62개 작성하였습니다
Very impressive. Thanks a lot!
viona - 답글
hope it can help you somehow!
Phryne -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 24
30일 전: 86
전체 시간: 1,279
