주요 콘텐츠로 건너뛰기
How To Use And Maintain Your Planetary Mixer
    • Verify that the machine can handle your intended tasks such as kneading, whisking, and shredding.
    • Consult the user manual to understand the mixer’s attachments and functions for different recipes.
    • Ask about metal or plastic gears before purchase to ensure the gearbox meets your needs.
    • Do not assume a higher wattage guarantees better performance.
    • Limit strain on the motor by avoiding very heavy dough if dough capacity is exceeded.
    • Select the whisk attachment for whipped cream, egg whites, or airy batters needing extra aeration.
    • Set speed according to recipe instructions and allow enough time for the mixture to become fluffy.
    • Use the beater for tasks like mashing, creaming, or creating crumbly dough.
    • Install the splash guard if supplied to avoid spattering around your work area.
    • Select a slow speed for initial blending and gradually increase as necessary.
    • Connect the attachment carefully, aligning it with the mixer’s drive slot.
    • Select an appropriate blade size for apples, nuts, or similar produce being shredded.
    • Operate at a medium speed and use a container to catch the grated ingredients as they come out.
    • Use the dough hook for heavy tasks such as bread, buns, or pizza bases.
    • Protect the drive shaft from dough by ensuring the plastic guard is in place.
    • Keep kneading speeds moderate to reduce stress on the gearbox and motor.
    • Avoid pushing the mixer to its limit with heavy mixtures for extended times.
    • Disconnect the power cable whenever you inspect or clean internal parts to prevent electric shock.
    • Remove attachments and clean them thoroughly to prevent residue buildup.
결론
By selecting the right attachment, adjusting the speed properly, and maintaining a clean, stress-free environment for your mixer, you will keep it in top condition for a long time. Always unplug the device before doing any internal checks or repairs, and stay within the limits of the warranty by following manufacturer guidelines. Solid maintenance and thoughtful usage ensure a reliable, lasting appliance.
작성자
2다른 기여자 명과 함께
Ula Gantar
회원 가입일: 01/08/25
16,474 평판
안내서 48개를 작성함
ZEOS Slovenia ZEOS Slovenia 회원
Local Repair Groups
2 회원들
안내서 56개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 9
전체 시간: 103
