• After a considerable period of time, MIUI developers released Xiaomi pc suite 3.0 beta version in order to make the tool compatible with Android 6.0 marshmallow devices. But this is still in beta version and seems some features do not process successfully.
    댓글 쓰기
    • Need to download into a Windows PC. Windows 7,8,8.1, Windows 10 compatible with this tool. Many smart phones from mi model, Redmimodel and also Redmi note mobile smart phones which running above instructions of Android 5 now compatible with this beta version. It included a new faster installation method but it only supports MIUI 9 ROM.
    댓글 쓰기
    • Download mi pc suite 3.0 beta version into your pc and rename it to prevent from some possible errors. Run the exe file as the administrator.
    • After successful installation, the tool itself will launch. Now sign into mi account. Enable USB debugging mode of your mobile.
    • Connect your mobile to the PC. you will see a window for authorization. Click on OK in order to recognize your mobile. After successful recognition, you will see your phone specs display on the Mi pc suite.
    댓글 쓰기
  1. Fixmas/픽스마스 분위기를 띄우세요
    FIXMAS12 코드로 $50 이상 구매시 $12 할인을 받으십시오
    • This tool can be used to flash the recovery ROM through recovery mode. This method can be used to fix the boot loop issue or to update to latest ROM version.
    댓글 쓰기
    • Select the fourth option available on top of the menu bar.
    댓글 쓰기
    • Boot your phone into recovery mode. Before that disconnect your mobile from the pc. Note: how to boot into recovery mode press volume up and power button altogether alternatively navigate to settings> my device> system update> click three dots on top right corner> reboot mobile to recovery mode.
    댓글 쓰기
    • Step 3: Press volume down button. select "connect mi assistant" by using power button. Step 4: Phone will show an image of the phone with a USB plug in Step 5: Now reconnect your mobile to the PC and the tool to recognize your mobile.
    • Step 6: Download a suitable ROM file or else you can download a one from the tool. Step 7: Now you will redirect to another option where to chose to 'save data or not to save'. Suggest you to backup all your important data.
    • Step 8: Now choose the ROM either you have downloaded or selected from mi pc suite. Wait few minutes until verification is done by the tool and it will start the installation process. Wait a few minutes until your mobile boots up. But you have to follow this method at your own risk.
    댓글 쓰기
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joy merryman
회원 가입일: 2018년 11월 01일
181 평판
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 30
전체 시간: 29
