주요 콘텐츠로 건너뛰기
How do I patch a garment?
필요한 것
    • Using a piece of tailor’s chalk, outline the size of the patch you’ll need to fully cover the area.
    • In order to ensure that the patch looks good and fits the garment, take note of any seams or design elements you can use to design your patch.
  1. How do I patch a garment?: 2 단계, 이미지 1개 중 1개
    • Transfer the size and shape of the patch to an appropriate piece of fabric for the patch.
    • Add 1 cm for a seam allowance along the entire patch.
  2. How do I patch a garment?: 3 단계, 이미지 1개 중 1개
    • Cut along the outer line of the patch.
  3. How do I patch a garment?: 4 단계, 이미지 1개 중 1개
    • Fold over the seam allowance on the patch and iron it down – this will help with sewing the patch on.
    • Lay the patch on the marked line and top stitch it to the fabric close to the edge of the patch.
    • You can use pins to attach the patch to the jacket so it won’t slide around while you’re sewing it on.
    • Use a top stitch to sew around the patch, locking off the first and last stitches by stitching back and forth a few times.
    • Cut away the torn area inside the jacket along the new seam.
결론
Done! You made it.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
VAUDE Reparaturteam님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
VAUDE Reparaturteam
회원 가입일: 02/22/16
6,602 평판
안내서 32개를 작성함
Vaudesport Vaudesport 회원
Community
3 회원들
안내서 97개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 47
전체 시간: 4,164
