주요 콘텐츠로 건너뛰기
How do I replace a broken buckle on my backpack?
필요한 것
  1. How do I replace a broken buckle on my backpack?, Buckle on backpack: 1 단계, 이미지 1개 중 1개
    • In order to determine the correct buckle size, measure the webbing. The webbing illustrated here is 15 mm, so you would need a 15 mm buckle.
  2. How do I replace a broken buckle on my backpack?: 2 단계, 이미지 3개 중 1개 How do I replace a broken buckle on my backpack?: 2 단계, 이미지 3개 중 2개 How do I replace a broken buckle on my backpack?: 2 단계, 이미지 3개 중 3개
    • Remove the broken buckle from the webbing by first pulling the webbing through the locking strap and then unthreading it from the buckle.
    • Use a screwdriver or tweezers to help pull the webbing through, if necessary.
결론
Follow the instructions in reverse order to finish your repair.
다른 6명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
VAUDE Reparaturteam
회원 가입일: 02/22/16
6,602 평판
안내서 32개를 작성함
Vaudesport Vaudesport 회원
Community
3 회원들
안내서 97개를 작성함
1가이드 댓글
Used to use Ortlieb panniers and I have recently changes to Vaude Aqua Back Plus for some incremental additional volume and also the external pocket. I could see that it is easy to replace the male end of the buckle but I guess it could almost be the end of the bag if the female end is broken?
…or maybe you could show us as well how to fix that too, so that we could have some comfort other simply praying that this would not happen!
tahiruysal - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 57
전체 시간: 20,139
