소개
VAUDE uses premium zips from YKK and other brand name manufacturers. Nevertheless, frequent or improper use can cause the slider to become bent or expand so the teeth no longer zip together.
It only takes a few steps to replace the slider – read on to find out how.
필요한 것
Done! You made it.
Done! You made it.
다른 9명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 6개
Hallo Rosselba, Prinzipiell steht immer hinten auf den Slidern eine Buchstaben/ Zahlen - Kombi. Anhand der kann man ablesen welcher Slider als Ersatz passen würde.
Links zu den Ersatzteilen könnten besser sein. Komme immer zuerst auf Angebote für neue Kleidung..
Hi
Zipper sliders are available here: https://www.shelby.fi/?cPath=402_31_82
For example the type in pictures: https://www.shelby.fi/product_info.php?p...
Stoppers available here: https://www.shelby.fi/product_info.php?c...
(this one is easier to install than the one in pictured in instructions)
